Normal Topic Deleting node with attached icons leaves icons (Read 1626 times)
consolejoker
Dec 31st, 2007 at 12:14am
Using the Entities sample, if you add an entity node, and then delete it, the little help button and the other icon is left on the diagram view.
Is there something special you have to do when deleting a node that has other nodes or items attached to it?
Re: Deleting node with attached icons leaves icons
Reply #1 - Jan 1st, 2008 at 5:14am
After attaching the items, set table.SubordinateGroup.AutoDeleteItems = true.
consolejoker
Reply #2 - Jan 1st, 2008 at 7:18pm
Thanks that worked!
