Normal Topic Invoke repaint of selection rectangle (Read 1738 times)
Alex
Jan 2nd, 2008 at 4:14pm
I've got the following problem: If I select some objects, the bounding rectangle is painted. After that I arrange the objects programmatically but the selection rectangle is still in the same place.
I want the rectangle to be painted around the new coordinates of the arranged objects. Is there an easy way to accomplish that with builtin mechanics ?
best regards and a happy new year!
Alex
Re: Invoke repaint of selection rectangle
Reply #1 - Jan 2nd, 2008 at 5:24pm
There is a private method that does that, and it seems we should make it public for use in such situations. You can call that method indirectly through some of the methods that change the selection state of an item. For example call Selection.Toggle(someRandomItem) twice, and the selection rectangle will be updated.
Reply #2 - Jan 2nd, 2008 at 5:26pm
... and Happy New Year to you too!
