Normal Topic replace picture (Read 1776 times)
allen
replace picture
Jan 6th, 2008 at 1:10pm
I used the LoadPicFromRes method to put a picture to the box control.But now I want the gray the picture of the box control that means the box control is unavailable.that is to say, how to load a grayed bitmap to replace the original bitmap,
Re: replace picture
Reply #1 - Jan 7th, 2008 at 6:46am
If you are using GDI+, you could overlay the box with another box whose FillColor is set to gray and FillColorAlpha is < 255, say 100. If the users must be able to interact with the 'unavailable' boxes, use a Group object to attach the overlay box to the picture box.
Another possibility is to use custom drawing and draw on the HDC / Graphics surface. Yet another one is to keep two versions of the image - a normal one and a grayed one.
