Normal Topic Custom Theme (Read 1755 times)
dimmer
Custom Theme
Jan 9th, 2008 at 4:22pm
Hi
I'm trying to create a custom theme using the Theme Editor.  However, when I try to apply settings for CommonReference and PlannerReference (Options-->Settings) I get the following error:
"File or assembly name Microsoft.VisualBasic.Compatibility, or one of its dependencies, was not found."
Since the Theme Editor.exe is located in the .NET 1.1 folder does this mean that I cannot create custom themes for projects based on the 2.0 framework?
Thanks for any suggestions
Re: Custom Theme
Reply #1 - Jan 10th, 2008 at 5:59am
There is a special build of the ThemeEditor for .NET 2.0. However, the error seems to be caused by the use of some old VisualBasic controls that are not present on your machine.
Contact me via e-mail meppy@mindfusion.eu and I will send you a build for .NET 2.0 that does not use those controls.
