Normal Topic Clickonce deployment (Read 3251 times)
prabhakar
Jan 11th, 2008 at 12:28pm
Does flowchart.net support click once deployment?
I could not find any reference to it in the developers reference.
Thanks in advance,
prabhakar.
Aaron
Looking for support
Re: Clickonce deployment
Reply #1 - Jan 11th, 2008 at 12:46pm
I'm currently creating a click once application and this causes no problems at all.
What exactly do you mean by "support it"?
Reply #2 - Jan 11th, 2008 at 1:09pm
ClickOnce installed applications should work fine out-of-the-box. ClickOnce online applications, which run directly from the web page, might have to run under the FullTrust permission set, depending on what features you need to use (e.g. access to the file system and the printer).
prabhakar
Reply #3 - Jan 11th, 2008 at 2:25pm
Thanks for your quick reply. I wondered when I did not find any reference to deployment or clickonce in the reference manual.
I wanted to make sure that it is really supporting click once with out the requirement to copy some files to System32 folder or writing some settings to registry.
one example is crystal reports which they claim supporing click once from version 11 onwards. but that is not really true. it is just giving a facility to select crystal reports as part of the click once deployment to treat it as a prerequisite. At the end we need admin rights on the end user machine to install it.
Therefore, my question is whether I will be able to run my application referring FLOWCHART.NET dlls by just keeping the application and all the FLOWCHART.NET dlls in the same folder on the end user machine.
/Prabhakar
Reply #4 - Jan 12th, 2008 at 7:17am
Flowchart.NET does not require any special deployment steps, it is enough to just have its assemblies copied into the application's folder.
Here is a ClickOnce installed version of one of the Flowchart.NET samples:
http://mindfusion.eu/_samples/ClickOnce1/publish.htm
And this is the online version:
http://mindfusion.eu/_samples/ClickOnce2/publish.htm
You will need to uninstall the installed version before trying the online one.
I have created both using the VS2005 Publish Wizard available form the project properties window.
prabhakar
Reply #5 - Jan 14th, 2008 at 8:48am
Stoyo and Aaron, thanks a lot for your prompt response.
/Prabhakar
