Normal Topic FlowChart is not marked as serializable (Cut/Copy) (Read 1864 times)
evans1dd
Jan 11th, 2008 at 8:01pm
I was just given support for a system in C#. When executing the CutToClipboard or CopyToClipboard methods I get this error:
Type 'MindFusion.FlowChartX.FlowChart' in Assembly 'FlowChart.NET, Version=4.1.0.23235, Culture=neutral, PublicKeyToken=a0d18338041985ba' is not marked as serializable.
I know there's not alot of information here, but I'll try to answer any questions that I can.
[code]
public ChartObject _currentObject = null;
private PointF _pasteDeltaPoint = new PointF(10, 10);
private bool _isPasteAction = false;
public void OnCopy(object sender, EventArgs e)
View.TheFlowChart.CopyToClipboard(false, true);
public void OnCut(object sender, EventArgs e)
View.TheFlowChart.CutToClipboard(false);
public void OnDocCut(object sender, EventArgs e)
public void OnDocPaste(object sender, EventArgs e)
_isPasteAction = true;
View.TheFlowChart.PasteFromClipboard(_pasteDeltaPoint.X++, _pasteDeltaPoint.Y++);
public void OnDocCopy(object sender, EventArgs e)
[/code]
Re: FlowChart is not marked as serializable (Cut/C
Reply #1 - Jan 12th, 2008 at 7:34am
Does your application display Flowcharts inside ControlHost nodes? In such case, you could handle the SerializeControl and DeserializeControl events to implement serialization of the hosted flowcharts (by means of the SaveToString and LoadFromString methods for example).
You might get a similar exception if the Tag of an item refers to a Flowchart instance. In such a case, set the Tag to null before calling CopyToClipboard, and restore it after that.
