Normal Topic How to detect embeded control type that is selecte (Read 2174 times)
Binary_Poet
Jan 17th, 2008 at 10:39am
I am trying to figure out how to tell the type hosted control in a node when a user selects the node (Diagram1_NodeSelected event...
Basically what we have is a designer where the user can draw a form with textboxes, labels, etc. I need to be able to detect the type of control they selected so I can show certain properties to them to change (ie: text, color, font size, etc)... we do not want to display every property as many of our users will get confused with every property available...
Thanks for any information!
Re: How to detect embeded control type that is sel
Reply #1 - Jan 17th, 2008 at 11:11am
Cast the Node event argument to ControlNode and use its Control property, e.g.
if (e.Node is ControlNode)
	ControlNode node = (ControlNode)e.Node;
	if (node.Control is Button)
		Button button = (Button)node.Control;
		// now show the button properties ...
Binary_Poet
Reply #2 - Jan 17th, 2008 at 2:09pm
I am sorry for having a "blond moment" but having trouble figuring this one out. It is saying that ControlNode is a type and cannot be used as an expression.......
Imports MindFusion
Imports MindFusion.Diagramming
Imports MindFusion.Diagramming.WinForms
Private Sub Diagram1_NodeSelected(ByVal sender As Object, ByVal e As MindFusion.Diagramming.NodeEventArgs) Handles Diagram1.NodeSelected
       If (e.Node Is MindFusion.Diagramming.WinForms.ControlNode) Then
       End If
    End Sub
Reply #3 - Jan 17th, 2008 at 2:17pm
Should look like this in VB:
If TypeOf e.Node Is ControlNode Then
	Dim node As ControlNode = DirectCast(e.Node, ControlNode)
	If TypeOf node.Control Is Button Then
		Dim button As Button = DirectCast(node.Control, Button)
		' now show the button properties ...
	End If
End If
You might take a look at the FormEditor sample project, since it is very close to what you are doing.
Binary_Poet
Reply #4 - Jan 17th, 2008 at 2:22pm
All I can say is wow! We just started to look at this toolkit and the support has been GREAT!!!!
S.
