Very Hot Topic (More than 25 Replies) PDF exporter problems (Read 11413 times)
Aaron
Looking for support
Re: PDF exporter problems
Reply #15 - Feb 13th, 2008 at 8:23am
I've been looking at the PDF export possibilities for version 5.
One thing I really would love seems to be in there, making a PDF file where the page size equals the chart's bounding rectangle. Using the PageSize.DiagramSize from MindFusion.Pdf.
I've been looking around but this is not possible for 4.3.1 right? I really can't just get up and change our version now, so any easy way to get this in 4.3.1?
Could you please confirm that this IS possible in version 5?
Reply #16 - Feb 13th, 2008 at 10:39am
Yes, that's possible in version 5. Here is an easy way to use it:
- create a tool that references the V5 assemblies
- read two file names specified via the command line
- call Diagram.LoadFromFile(param1)
- PdfExporter.Export(param2)
- run that tool from your current application when you need to export to PDF
Aaron
Looking for support
Reply #17 - Feb 25th, 2008 at 9:08am
As I wasn't doing that much with Mindfusion at the serverside (where I'm generating the PDF) I changed to 5 all together. Just one question now, since I'm on a server, I'd be more happy if the PDF file was generated directly on a memory stream.
However, even though we have the source code license, MindFusion.Pdf is not part of this, and it is the PdfGraphics object that requires a filename.
I was wondering if there was a way around writing a pdf to disk for me...
Aaron
Looking for support
Reply #18 - Feb 25th, 2008 at 10:57am
An additional question has posed itself about this PDF exporting with FC.NET 5. Could you please tell me which specific version of PDF (I believe the standard is updated now and then with new features and syntax and so on right?) FC.NET 5 is using.
I'm importing the pdf into another pdf file using a software component called "tallpdf". However, even though it was working fine with 4.3.1, importing the PDF generated by 5 throws an error (a rather obscure one) that I think indicates a compatibility problem. The TallPDF component expects "a dictionary while reader trailer". I've no idea what that means, maybe somebody with PDF experience has? But it seems to me, he's expecting something that isn't there and my guess is that it is expecting another version of the PDF format...
Reply #19 - Feb 25th, 2008 at 12:51pm
The source code zip file contains the following directories:
Common
FlowChart.NET
PdfLib (this is the source for MindFusion.Pdf)
SvgLib
As far as I know, MindFusion.Pdf is based on the PDF 1.6 specification.
Aaron
Looking for support
Reply #20 - Feb 26th, 2008 at 5:54am
Oh ok, it wasn't there in the 4.3.1 source code (I double checked) so I was assuming too rapidly it wouldn't be there for 5.
Anyway, I've been looking at what might be going wrong, comparing PDF's from 4.3.1 with those from 5. Making sense of the error message I've made a little discovery.
Right at the start of the "cross-reference table" there's a line saying: "0 23"
This, according to acrobat, should indicate the first index and the last index of the elements in the table. Counting 24 items in the table, this seems correct on mindfusion's part. However, I saw that in the PDF from 4.3.1 the latter of the two numbers indicated the length of the table (so the amount of elements) rather than the last index.
Also, in the trailer there's an entry "/Size 23". Which should indicate "the total number of entries in the cross-reference table". So this should be at least 24. Changing this value alone, doesn't solve my problem. But changing both the 23 at the start of the cross-reference table AND the 23 in the trailer to 24 resolves the issue and the TallPDF software component can now read the PDF without problems.
Acrobat reader can handle all of these files without complaining, so I'm thinking the problem might be with TallPDF itself.
I don't have much of an idea about the PDF format, but I now know how to fix the problem for me personally. I just thought I'd mention it to the people more experienced in creating the PDF files. Maybe there's a good reason for those particular numbers?
Reply #21 - Feb 26th, 2008 at 9:37am
Are there the same number of entries in the crossref tables created by both versions of the exporter? From what I can make out of the specification, the second number should not indicate the last index, but the number of entries in the section. Our developer will check if the latest version writes there the size or the last index.
Aaron
Looking for support
Reply #22 - Feb 26th, 2008 at 10:49am
Yes, the old version writes the same value on the two locations, more specifically the total of items in the cross-reference table.
In code, as far as I see, the new MindFusion.Pdf still does this, only it's now writing the last index instead of the total amount of items. It's using seemingly the same value on both places in the PdfHelper class:
(arg as PdfDocument)._helper.CurrentId();
Here's the content of the cross-ref table and trailer for two pdf's I've been using as a reference:
Generated by the 4.3.1 code:
xref
0 18
0000000000 00000 f
0000000017 00000 n
0000000119 00000 n
0000000185 00000 n
0000009617 00000 n
0000010728 00000 n
0000010844 00000 n
0000010960 00000 n
0000011076 00000 n
0000011192 00000 n
0000011308 00000 n
0000011425 00000 n
0000011542 00000 n
0000011659 00000 n
0000011776 00000 n
0000011893 00000 n
0000000541 00000 n
0000012010 00000 n
trailer
/Size 18
/Root 1 0 R
You can count 18 entries in the table.
Generated by the new 5.x code:
xref
0 13
0000000000 00000 f
0000000017 00000 n
0000000121 00000 n
0000000187 00000 n
0000000469 00000 n
0000000717 00000 n
0000000769 00000 n
0000001017 00000 n
0000001069 00000 n
0000001273 00000 n
0000001503 00000 n
0000001719 00000 n
0000002838 00000 n
0000003138 00000 n
trailer
/Root 1 0 R
/Size 13
You can count 14 (!) elements in the table
My customisation simply adds 1 to the CurrentID() at both places where it's used in the PdfHelper class.
Reply #23 - Feb 26th, 2008 at 12:22pm
Ok then, we'll do that customization too 8) From my understanding, a missing xref entry should simply make object lookup slower, but apparently the TallPDF implementation is stricter in this regard.
Reply #24 - Feb 28th, 2008 at 10:00am
If it's not a secret, could you post your code that uses TallPDF and threw that exception? We will add it to our tests to prevent the problem from happening again.
Aaron
Looking for support
Reply #25 - Mar 12th, 2008 at 9:26am
I can't just copy paste all my code, as it wouldn't even be helpful. Really all you need to do to reproduce the problem TallPDF is having with the PDF files created by FC.Net is the following (I'm assuming you know how to export to pdf with FC.NET Wink):
TallComponents.PDF.Layout.PageShape newShape = new TallComponents.PDF.Layout.PageShape("file.pdf", 0, null);
The file.pdf file is a file created by FC.Net
This will try and create a "PageShape" from the given pdf file (in my code I'm reading it from a stream but it's the same difference).
Note I was using the demo version (freely downloadable) of TallPDF 2.0... right now they only offer TallPDF 3.0, so maybe this version wouldn't have any problems at all. I don't know...
Hope it's helpful.
Aaron
Looking for support
Reply #26 - Mar 12th, 2008 at 9:42am
I also noticed my previous statement "just added 1" is a bit wrong. I'm actually doing this inside the Format method of PdfHelper class in MindFusion.Pdf
                case cFormatEnum.PdfTrailer:
                    System.Diagnostics.Trace.WriteLine("Added one to id in the trailer...");
                    result = (arg is PdfDocument) ? String.Format(Globals.TrailerPattern, (arg as PdfDocument)._helper.CurrentId() + 1, (arg as PdfDocument)._xref_position) : "";
                    break;
                case cFormatEnum.PdfXref:
                    if (arg is PdfDocument)
                        PdfObject obj = null;
                        Int32 LastId = (arg as PdfDocument)._helper.CurrentId();
                        result += String.Format(Globals.XRefPattern, LastId + 1);
                        System.Diagnostics.Trace.WriteLine(string.Format("{0} + 1 = {1}", LastId, LastId + 1));
                        for (Int32 i = 0; i <= LastId; i++)
                            obj = (arg as PdfDocument)[i];
                            result += String.Format(Globals.XRefEntryPattern, (obj == null) ? 0 : obj.Offset, 0, (obj == null) ? "f" : "n");
                    break;
Reply #27 - Mar 12th, 2008 at 2:31pm
Thank you 8)
Aaron
Looking for support
Reply #28 - Feb 10th, 2009 at 2:25pm
Sorry to bring this up again. I'm assuming this problem has been addressed in version 5.1.1. Is this correct? Also, do you know what the first version was this was fixed in?
Thanks!
Aaron
Reply #29 - Feb 10th, 2009 at 2:43pm
One of the tests in our unit test project now calls the TallPdf's PageShape constructor, so that should work fine, unless TallPdf stopped throwing exceptions for this.
