Hot Topic (More than 10 Replies) Run Time Drag and Drop (Read 6916 times)
Re: Run Time Drag and Drop
Reply #15 - Feb 4th, 2008 at 5:49pm
You could define a custom shape whose text region is set slightly below the shape. Another option is to attach a transparent node to the main shape and display the text there (see the Transparent property and AttachTo method).
SC
Reply #16 - Feb 4th, 2008 at 8:35pm
Hi
I was able to attach text as you suggested but how can I trace back the node that has been attached to the node that has been selected? as I have changed the text through properties but since it is tied to node, it is not udpating the text below it.
I mean is there any method that finds the node attached to a node?
Also how can I export just portion of the drawing instead of the whole things? I am trying to show the relations hierarchically in treeview but when I click on the treeview particular node, it has to show only the conenction below it on the canvas..
Reply #17 - Feb 5th, 2008 at 7:53am
You can access attached nodes through the mainNode.SubordinateGroup.AttachedNodes collection.
You could use the Visible property to show or hide some subset of the diagram items.
