Normal Topic TimetableSettings.GeneralFormat doesn't do anythin (Read 7396 times)
Jeffry
Jan 21st, 2008 at 11:14am
I'm working with release 4.2 of PocketPlanner. I noticed that although I set the TimetableSettings.GeneralFormat to a certain format using:
calendar1.TimetableSettings.GeneralFormat = DateTimeFormatInfo.CurrentInfo.ShortTimePattern;
It doesn't use this format.
I tracked it down to the ScheduleCell.DrawTimeLineV method where it looks for a value "round". If round then it uses settings.HourFormat for the hour and "00" or AM/PM for the minutes.
If round=false, then it uses the GeneralFormat property.
I was able to fix it by setting GroupHours to false. However, I would like to know if this is expected behavior.
I would like to have one place where I set the datetime format, i.e. the GeneralFormat property and not have to worry about also setting other properties like TwelveHourFormat.
Also, maybe related to this. I changed the GroupHours from true to false to fix the problem and nothing further changed in my timetable view. It still shows one hours per cell like I defined.
What is the effect of setting GroupHours to true?
Jeffry
Re: TimetableSettings.GeneralFormat doesn't do any
Reply #1 - Jan 21st, 2008 at 11:27am
GroupHours' effect can be observed only when the CellTime property is set to less than an hour. Additionally the CellTime value should divide one hour completely (for example: 1, 2, 5, 10, 15, 20 or 30 minutes). When these conditions are met, the timeline displays a single label for the hour and several labels representing the minutes in each individual cell, corresponding to that hour.
Because of this, GeneralFormat cannot be applied in this case since the hours and minutes are displayed separately and they require different formatting.
I hope this explains the behavior you have noticed.
Jeffry
Reply #2 - Jan 21st, 2008 at 11:34am
Ok, so when I have the CellTime set to one hour, then I can just set GroupHours to disabled and then it uses the GeneralFormat.
BTW, I noticed that 13:00 displays fine, but 1:00 PM takes up too much space and PM is on the next line. How do I solve that?
Reply #3 - Jan 21st, 2008 at 12:58pm
Yes.
Have you tried to increase the size of the timeline (through the Calendar.TimetableSettings.TimelineSettings.Size property).
Jeffry
Reply #4 - Jan 21st, 2008 at 1:20pm
Indeed it was the TimelineSettings.TimelineSize property.
