Hi, I have a number of issues regarding the creating and maintaining of recurrences, as follows:
1.
After I have made all the required entries to a new recurrence I set the items recurrence like this:
myItem.Recurrence = myNewRecurrence
The calendar is correctly updated with the recurrence details.
When I step thru the code myItem.Recurrence correctly displays the newly created recurrence.
But when I save the data back to the table the data is saved correctly to each table except the Recurrence field in the Item table remains null (nothing)?
The recurrencestate field displays 3 instead of 0 signally to me that it knows it has a recurrence?
Is this happening because in the call to the SaveToDataSource method the Recurrence table is updated AFTER the Item table meaning at point of save there is no Key present in the Recurrence value to save to the Item table?
2.
As soon as I assign the recurrence to the item.recurrence property the calendar automatically updates to display an appointment for each occurence.
But none of the methods of the calendar get called to signal an appointment has been created? This means my month view calendar does not display highlights on each day a occurence recurs?
3.
The user guide refers to fields that do not appear in a Recurrence object, namely:
recurrence.StartHour
recurrence.StartMinute
recurrence.EndHour
recurrence.EndMinute
Am I missing something as my version does not have these fields?
4.
Currently I get 1 row for an appointment in the Item table and 1 row for a recurrence in the Recurrence table.
If I have a daily recurrence to recur 3 times and I then edit the 2nd occurence to start at a different time where is this diffence stored as I cannot see in the Recurrence table how it would store multiple start and end times in a single row?
Sorry for the mass of questions .....
