Normal Topic Running out of anchor points. (Read 1553 times)
MagnusSpeychal
Jan 30th, 2008 at 7:24am
Hi
If I try to attach an arrow to an anchor point which does not exist, i.e. using the CreateAnchoredArrow-method with a reference to anchor point 5 when there are only 4, I get different results. Is it up to me to handle these situations or is this handled in some predefined way by FlowChartX.
Best regards,
Magnus
Re: Running out of anchor points.
Reply #1 - Jan 30th, 2008 at 9:54am
In that case it should work just like CreateArrow - the arrow is drawn between the centers of the two boxes, and its ends are moved to the points where it intersects the boxes' outlines.
