Normal Topic Guru advice please? (Read 3613 times)
elpuerco
Time?  What's time matta
to a pig?
Guru advice please?
Feb 3rd, 2008 at 3:04pm
Hi Meppy & Stoyan, may I pick your brains please on how best to deal with this bit of my application?
Following you help on with my recurrence problems I now have my app using the inbuilt appointment and recurrence forms and have changed it so I now make changes to the app.config file and leave the registry alone!   Wink
From a previous post I asked about being able to identify recurrences so I could update the highlighting on the monthview.
All appointments are set on the timetableview calendar.   When any are added or deleted the matching date on the monthview calendar has its highlight set to yellow to signal an appoiment on that date.
As the recurrences are temporary you said I could query the schedule.getallitems method.
However this method requires a date range.
My question is this:
Should I call this method with a start and end date so huge it gets all items from the birth of Christ until the end of mankind or only for the 4 months on current view on the monthview calendar?
Is it better to call this method each time the date range on the monthview changes?
thanks.
BTW when you kindly looked at my app (and cringed I'm sure) you mentioned some bindings that were stopping debugging assemblies from being loaded?
Is this something I need to address here so I get more control over debugging my apps?
Thanks ...
Re: Guru advice please?
Reply #1 - Feb 4th, 2008 at 6:07am
No. If you have infinite recurrences, such operation might take extremely long.
This is the preferred solution. Just regenerate all items in the corresponding range of 4 months every time this range changes or a new recurrence is created.
No, it just prevented your project from loading our own debug dlls. It might cause problems for you in the future if you start using newer version of Planner.NET however.
Hope this helps.
elpuerco
to a pig?
Reply #2 - Feb 4th, 2008 at 8:27am
Meppy wrote on Feb 4th, 2008 at 6:07am:
Thanks Meppy, I will take your advice.
Re the possible future problems what exactly was it in my app that caused you problems and me maybe in the future?
Better to address it now!
Reply #3 - Feb 4th, 2008 at 11:21am
It was in the .config file as long as I recall. Just look for a "3.1." in there and remove any static references to a specific version of Calendar.dll.
elpuerco
to a pig?
Reply #4 - Feb 4th, 2008 at 12:20pm
I have entered code in the VisibleDateChanged event of my month view calender to track the 4 months being displayed
I see I can get the previous and new visible dates but they range from the actual current date rather than the 1st and end of month for example:
01/02/2008 - 30/05/2008
I use this
e.NewDate.AddDays(-e.NewDate.Day + 1)
but find this to be messy and to do something similar to get the end day of the 4th month seems even messier!
Any tips?
Reply #5 - Feb 4th, 2008 at 12:51pm
Have you tried calling the GetFirstVisibleDate and GetLastVisibleDate methods of the Calendar class? Anyway calculating the first and last days in the visible range isn't that messy.
elpuerco
to a pig?
Reply #6 - Feb 4th, 2008 at 1:22pm
OK I will stick with the calculating method.  I had already tried the GetFirstVisible date etc but these return the dates prior to the caladar being updated?
The e.newdate and e.previousdate are the ones that report the near right info :0
