Normal Topic Dynamic Links (Read 7496 times)
Paul Eden
Dynamic Links
Feb 4th, 2008 at 9:24am
Hi Stoyan
Was wondering if you could tell me what I'm doing wrong Smiley
As part of a routine, I have a node on a diagram created by instancing a UI control in code. From that I then create other controls in code and link them to the first via the attach to method. Because this does not generate a visual link I also create a link objects. When I then move the first node (again as part of the routine) for centering purposes via the Diagram.SetItemLeft method, the nodes origin points 'stick' to where the parent control was, rather than following it. I have set the dynamic property on the link objects to True, but this has not had any effect.
Any insight would be greatly aprieciated.
Many thanks
Paul
Re: Dynamic Links
Reply #1 - Feb 4th, 2008 at 10:20am
Hi Paul,
For now use the DiagramNode.Move method to center the node, it seems to work. Our developer will examine why the attached property doesn't move the whole group.
Paul Eden
Re: Dynamic Links
Reply #2 - Feb 4th, 2008 at 12:02pm
Hi Stoyan
Thanks for that - the links now stay attached to the parent node.  As an off shoot of this, I was looking to only move the parent node.  When using the DiagramItem.Move method, it is as if the User has moved the node and as such the entire group moves.  When the Diagram.SetItemLeft is fixed, will it have the same result or do I need to set anything on the group to temporarily keep it in place?
Paul
Re: Dynamic Links
Reply #3 - Feb 4th, 2008 at 12:43pm
Hi Paul,
Setting the ItemLeft attached property will have the same effect as calling Move. As a work-around, you can center the child items instead of the parent one, or center the parent before creating the groups.
Paul Eden
Re: Dynamic Links
Reply #4 - Feb 4th, 2008 at 2:58pm
Ok, thanks for that - time to shunt some code around Smiley
Paul
