Normal Topic ControlNode size based on Control (Read 1544 times)
SavyCat
Feb 11th, 2008 at 8:22am
Hi guys, how do you make it so that a ControlNode's bounds are as big as the UserControl that I specify as its control property. I tried the obvious:
Bounds = new RectangleF(0,0,Control.Width, Control.Height);
But this is too large. Any help would be greatly appreciated. Ive looked at the differences between Rect and RectF and it says the '=' operator is supposed to make the conversion for you - but no luck.
Mat
Re: ControlNode size based on Control
Reply #1 - Feb 11th, 2008 at 11:04am
Hi Mat,
Use the ClientToDoc method to convert from the control's pixel coordinates to the diagram's millimeters (or whatever unit is set in MeasureUnit).
SavyCat
Reply #2 - Feb 11th, 2008 at 3:40pm
Oh of coourse Tongue Sorry bout that and thanks  Embarrassed
