Normal Topic Arrows without breaks (Read 2112 times)
Henry
Feb 11th, 2008 at 10:21am
when i try Box.MoveTo after a ArrangeDiagram, the Arrows gets more Segments.
I want only Arrows with 1 Segment (one line without breaks) , arrow.Style = asPolyline has no effect.
How can i change that?
MfG
Henry
Re: Arrows without breaks
Reply #1 - Feb 11th, 2008 at 10:58am
Set Arrow.SegmentCount = 1. Also check whether the AutoRoute property is enabled. If it is enabled, the control will add or remove segments ignoring your SegmentCount value.
Henry
Reply #2 - Feb 11th, 2008 at 11:19am
you mean Arrow.Segments = 1?
There are no SegmentCount property exists in the Arrow.
Autoroute=false works fine.
thx
Henry
Reply #3 - Feb 11th, 2008 at 11:52am
That's right.
