Normal Topic Move and delete Node in Diagram (Read 14525 times)
chris
Feb 11th, 2008 at 5:27pm
Hi Stoyan,
I noticed that in the Demo projects, some nodes in the diagram can be moved and deleted. But some nodes can not be moved and deleted.
I tried to write a prototype similar to drag and drop nodes to the diagram. But all the nodes created can not be moved and deleted.
Would you please tell me what kind of properties do I need to set to move and delete created nodes?
Thanks a lot!
« Last Edit: Feb 11th, 2008 at 6:48pm by chris »
Re: Move and delete Node in Diagram
Reply #1 - Feb 12th, 2008 at 6:26am
It should depend on the Locked and EnabledHandles properties whether the user is allowed to move a node. Could you post here the code you are using to create your nodes?
chris
Reply #2 - Feb 12th, 2008 at 1:08pm
I tried 2 ways.
1. Create a node with image + text
2. Just text
I think the Locked property is default to false.
Basically, I copy and paste the code from the demo project.
Thank you very much.
   void diagram_Drop(object sender, System.Windows.DragEventArgs e)
        Point p = e.GetPosition(diagram);
        Point pt = diagram.ClientToDoc(p);
        if (e.Data.GetDataPresent(typeof(Image)))
           Image i = (Image)e.Data.GetData(typeof(Image));
           ShapeNode b = diagram.Factory.CreateShapeNode(pt.X, pt.Y, 30, 30);
           b.Image = i.Source as BitmapSource;
           b.ResizeToFitImage();
           b.Transparent = true;
           ShapeNode bb = diagram.Factory.CreateShapeNode(
               pt.X - 10, pt.Y + b.Bounds.Height,
               b.Bounds.Width + 20, 5);
           bb.AttachTo(b, AttachToNode.BottomLeft);
           bb.Locked = false;
           bb.Transparent = true;
           bb.Text = "From image";
        else if (e.Data.GetDataPresent(DataFormats.Text))
           string s = (string)e.Data.GetData(DataFormats.Text);
           ShapeNode b = diagram.Factory.CreateShapeNode(pt.X, pt.Y, 30, 5);
           b.Text = s;
chris
Reply #3 - Feb 12th, 2008 at 1:10pm
I tried to add
b.EnabledHandles = AdjustmentHandles.Move;
It still doesn't work.
Are there some properties in the Diagram to control move and delete?
Also, I can't delete the node with del key. There is no response when I select and delete it with del key.
Thanks.
Reply #4 - Feb 12th, 2008 at 1:52pm
Please try that with the latest build of the control:
https://mindfusion.org/_beta/MindFusion.Diagramming.Wpf.zip
Does it work any better?
chris
Reply #5 - Feb 12th, 2008 at 2:50pm
Hi Stoyan,
The nodes can be moved.
I can't delete the node at the first time.
But I can delete it when I select press Del key the second time.
For the node with image and text, just the image is deleted. I can't delete the associated text.
I've send you the whole solution to support@mindfusion.eu.
Thank you very much!
Reply #6 - Feb 12th, 2008 at 4:03pm
Hi Chris,
HandlesStyle == DashFrame reserves a couple of millimeters near the node borders for drawing links, and the rest of the node interior can be used for moving nodes. This does not work in your case because the shapes are too narrow and their whole area is reserved for drawing links. Check if decreasing the HandlesSize value fixes that. If it doesn't, use another HandlesStyle or create larger nodes.
For Del to work, the Diagram control must have the keyboard focus. Every time you drag from the list, the focus goes to the list control, so you must click the diagram again to move the focus there (or use TAB).
After attaching the text node, set b.SubordinateGroup.AutoDeleteItems = true to have both nodes deleted when you press Del.
chris
Reply #7 - Feb 12th, 2008 at 4:48pm
Hi Stoyan,
After I changed the HandlesStyle == EasyMoce,
the move and delete operation work fine.
But I found another problem, every time I drag and drop, it creates 2 nodes. You can try the project I sent to you. ( I didn't see it before because I can't move the node.)
Thanks again!
Reply #8 - Feb 12th, 2008 at 5:45pm
Perhaps the event is raised for a second time if you do not set the DragEventArgs.Effects property?
chris
Reply #9 - Feb 12th, 2008 at 8:30pm
Thanks.
There are 2 Drag Events raised.
After I set "e.Handled = true" in the DragEventHandler, it works.
