Normal Topic How create a diagram reading a Treeview in Excel (Read 1867 times)
mariofel
Feb 11th, 2008 at 10:26pm
I have a treeview in a form in excel, how create a flow in Flowchart?
How create a box and Linking it to another box programatically?
Re: How create a diagram reading a Treeview in Exc
Reply #1 - Feb 12th, 2008 at 6:49am
Creating flowchart items in VBA should look like
set b1 = fc.CreateBox(10, 10, 40, 30)
set b2 = fc.CreateBox(90, 80, 40, 30)
set link = fc.CreateArrow(b1, b2)
Older versions of Office crashed when adding FlowChartX to a VBA form, because of type library size limitations in them. To work around that, you will have to create a user control that wraps FlowchartX and implement your application logic in the user control, then add it to the form instead of the FlowChart control.
