Normal Topic Not clear with EnableStyledText (Read 2586 times)
rcruzmar
Feb 14th, 2008 at 4:46pm
I am having difficulties with the EnableStyledText Property. The problem is that the Styled text does not display. the text is displeyed with the HTML-like tags displayed.
Here is a sample of what I am coding:
[code]
BoxItemStruct.boxItem = m_FlowCtrl.CreateBox(8, 8, 352, 320);
BoxItemStruct.boxItem.SetTextStyle(tsFitPolyBottom);
BoxItemStruct.boxItem.SetEnableStyledText(TRUE);
BoxItemStruct.boxItem.SetStyle(bsShape);
BoxItemStruct.boxItem.SetText("H<b>2</b>O"); //"<b>"+BoxItemStruct.strText+"<\b>");[/code]
This is almost a direct copy of the sample shown in the online help file.
Any ideas? Am I using an older version of the FlowChart ActiveX control?
Thanks for your help.
Rolando
Re: Not clear with EnableStyledText
Reply #1 - Feb 14th, 2008 at 5:01pm
I have pasted this in the "Text and Fonts" sample project and it worked fine.
b = fcx.CreateBox(8, 8, 352, 320);
b.SetTextStyle(tsFitPolyBottom);
b.SetEnableStyledText(TRUE);
b.SetStyle(bsShape);
b.SetText(_T("H<b>2</b>O")); //"<b>"+BoxItemStruct.strText+"<\b>");
Could you try that?
rcruzmar
Reply #2 - Feb 14th, 2008 at 5:45pm
Unfortunately this did not work. Below is an except of the code I copied and pasted from the Text and Fonts sample into my program.
// Create box replica
CFontHolder fh6(NULL);
CY fsize;
fsize.int64 = 80000;
fh6.InitializeFont();
BoxItemStruct.boxItem.SetFont(fh6.GetFontDispatch());
BoxItemStruct.boxItem.GetFont().SetName(_T("Tahoma"));
fsize.int64 = 100000;
BoxItemStruct.boxItem.GetFont().SetSize(fsize);
// Set values from the edited boxItem
BoxItemStruct.boxItem.SetText(_T("H<sub>2</sub>O"));
I am not able to display the text within the box with the Styled Text enabled. Could I have an older version of the Flow Chart control?
Rolando
Reply #3 - Feb 14th, 2008 at 5:55pm
But doesn't it work when you paste that in Text&Fonts and run the sample? If it works, compare the differences between your flowchart's properties and the ones in the sample. Also check whether your application isn't changing the box style at some point later.
rcruzmar
Reply #4 - Feb 14th, 2008 at 5:58pm
GOT IT TO WORK!!!!  Grin
The Text style was resetting to something else later in the code! Had I seen this before we would not have this conversation.
May this be a reminder to others to check their codes!!!
As always, thanks for your help and effort.
Rolando
