Normal Topic Problems with onBoxClicked event in imagemap mode (Read 2019 times)
oakenshield
Feb 27th, 2008 at 12:34pm
I'm encountering problems with onBoxClicked event in imagemap mode : the first time this event is raised after opening my web page, I have no problem... but the other times it is raised, the attribute e.Box is incorrect ! Indeed, e.Box doesn't correspond to the clicked box, but it is one of the other boxes of the diagram... It's quite annoying !
My code is like :
protected void map_onBoxClicked( object sender, BoxMouseArgs e )
    Box clickedBox = e.Box;
Do you have any idea about this curious issue ?
Thank you !
Re: Problems with onBoxClicked event in imagemap m
Reply #1 - Feb 27th, 2008 at 1:12pm
Try the Postback sample project. It handles BoxClicked and changes the color of the clicked box - does that work with your version of the dll?
oakenshield
Reply #2 - Feb 28th, 2008 at 7:15am
Okay my problem is solved : actually, I haven't put the diagram loading in a if ( !IsPostBack ) condition... That caused a little dysfunction of the onBoxClicked event...
Thanks !
