Normal Topic Moving anchor points, but links not updating (Read 4143 times)
SavyCat
Feb 29th, 2008 at 12:10pm
Hi guys, not sure if this is a bug or not. In my program I create a shape node with one anchor point. I then link that node to another node. After that, I add another anchor point to the original node and re-arrange all the anchor points so that they are evenly spaced on the node. This works fine - but the link that was created on the first point is not updating to the new position...Is it my responsibilty to change its position? If so - how would you recommend I do that?
SavyCat
Re: Moving anchor points, but links not updating
Reply #1 - Feb 29th, 2008 at 12:10pm
Forgot to say thanks Smiley
Reply #2 - Feb 29th, 2008 at 12:29pm
Try setting the OriginAnchor to -1, and then setting it back to its original value.
SavyCat
Reply #3 - Mar 3rd, 2008 at 9:54am
Ah, that did the trick. Thanks Stoyo
SavyCat
Reply #4 - Mar 3rd, 2008 at 10:32am
It looks like I found a bug. it seems to me that the origin indices are not getting reset when a point is removed. Try something like this:
List<int> indicesBefore = new List<int>();
foreach (outgoing link)
		indicesBefore.add(links origin index);
//Remove a point
List<int> indicesAfter = new List<int>();
		indicesAfter.add(links origin index);
SavyCat
Reply #5 - Mar 3rd, 2008 at 10:32am
//Remove a point
Reply #6 - Mar 3rd, 2008 at 12:23pm
We haven't designed the AnchorPattern objects to allow dynamic modification while they are in use. The control expects that you would define the AnchorPattern objects in your application initialization code, and then use them without changes in run-time (just like Shape definitions). So if you need to add or remove points dynamically, or change their positions, you will have to take care of updating the DiagramLink objects affected by these operations.
SavyCat
Reply #7 - Mar 3rd, 2008 at 12:57pm
Gotcha. Well, I managed a way around it. Thanks though.
SavyCat
Reply #8 - Mar 3rd, 2008 at 1:01pm
Hey Stoyo, id rather not start a new thread for this little  question. But how can I cancel a user from using the inplace editor?
I dont want the user being able to rename the links. Thanks
Reply #9 - Mar 3rd, 2008 at 1:23pm
If you need to disable that just for the links, handle LinkTextEditing and set e.Cancel = true.
