Normal Topic fit the text inside the box (Read 1951 times)
Jose
Mar 7th, 2008 at 10:07am
Hey Stoyan,
  How can I set the size (width) of the box with respect to the text it contains.. I saw one property FitSizeToText() but it was changing both the width and height, and that too to very large size. (bug?) I just need to fit the text correctly inside the box without affecting its height.
thanx in advance..
Re: fit the text inside the box
Reply #1 - Mar 7th, 2008 at 11:38am
Hi Jose,
When using the tsFitPoly* text styles, FitSizeToText keeps the initial aspect ratio of the box. You might use FlowChart.MeasureString to get the size needed to fit the text, and then set the box width to the MeasureString result. Add 1mm margins the found width, otherwise the text might not fit in the box.
Jose
Reply #2 - Mar 7th, 2008 at 11:54am
good results.. thanks..
