Normal Topic Bounds property (Read 1659 times)
gringogordo
Flowcharting is my life
baby
Bounds property
Mar 7th, 2008 at 3:14pm
I'm sure I'm being a bit slow on this buit I'm trying to format my diagram and I'm doing this by setting a nodes postion in relation to its parents position.
Obvioulsy I can store this myself but I was hoping to use the bounds property on the parent node.  Unfortunately this seems to be giving a different set of numbers back from those used to create the diagramnode.  so for example I'm starting off at X=400, Y=400 and when I get the node programatically and look at its bounds it tells me it's at X= 105, Y=53.   When I pass these back (+ a little on the Y param) into the creation of a new desitination diagram it is created above and to the left !
Does anyone know what I'm missing here?
Re: Bounds property
Reply #1 - Mar 7th, 2008 at 3:34pm
Are you using groups / the AttachTo method? In that case, moving one node would move the attached nodes too, changing their initial Bounds value. Or they could move if you call the Arrange method of some layout class after setting Bounds?
gringogordo
baby
Re: Bounds property
Reply #2 - Mar 7th, 2008 at 3:45pm
No,
It's all in the same procedure.  I have a set of objects in a database which I am using to build a diagram.
I set the first one
Dim oPointF As PointF = oView.ClientToDoc(New Point(400, 100))
oShape = oDiagram.Factory.CreateShapeNode(oPointF.X, oPointF.Y, 20, 10)
and then in the sampe procedure iterate through until I get the node with the correct tag (set to an id)
For Each oParentNode As ShapeNode In oDiagram.Nodes
                       If CType(oParentNode.Tag, Int32) = Id Then
grab node and get
oParentNode.bounds.top & left (or X & Y)
and these are  different to the values just used to set the parent diagram ?!
Cheers.
Re: Bounds property
Reply #3 - Mar 7th, 2008 at 3:56pm
ClientToDoc converts pixels to the diagram's MeasureUnit, so the Bounds top/left point won't be located at 400,100 in the diagram coordinate system. Additionally, the value returned by ClientToDoc depends on the current scroll position and zoom factor, so you could get different results depending on whether the diagram is zoomed or scrolled. If you need to convert from pixels to MeasureUnit without considering the scroll position, subtract ScrollX and ScrollY from the ClientToDoc result.
