Normal Topic Moving from older version to new version (Read 1234 times)
dinesh
Mar 7th, 2008 at 12:59pm
i hav written  code to draw radial tree in Mindfusion 3.0
Now i hav to upgrade this thing to MindFusion 5.0.
Earlier,I drawn using flowchart class.I used following methods.
[1] Createbox
[2]size
[3].createGroup
[4].createDiagramLink
I used Box  class with following method
[1].fillcolor
[2].Framecolor
In developers Guide you told to replace Flowchart with diagram & diagram View. And Box with ShapeNode
I did so..
Problem is I can't find corresponding equivalent methods for
          Diagram &
          Shapenode class implementation
Re: Moving from older version to new version
Reply #1 - Mar 7th, 2008 at 1:10pm
[1] Createbox  -> Diagram.Nodes.Add(new ShapeNode(...)) or Diagram.Factory.CreateShapeNode()
[2]size  -> Bounds
[3].createGroup  -> Diagram.Groups.Add(new Group(...)) or Diagram.Factory.CreateGroup();
[4].createDiagramLink  -> Diagram.Links.Add(new DiagramLink()) or Diagram.Factory.CreateDiagramLink
[1].fillcolor -> Brush
[2].Framecolor -> Pen
The Diagram.Factory methods let you create items from the standard types, while Nodes.Add and Links.Add let you create items from your custom types as well.
dinesh
Reply #2 - Mar 8th, 2008 at 6:26am
Working Fine thank you!
