Normal Topic Invisible tables and mouse events (Read 2672 times)
baron
Mar 11th, 2008 at 2:25am
Symptom: When clicking on tables or even arrows between tables, I sometimes don't get the click or double click event.
I discovered the cause of this was due to invisible tables that I think are grabbing the mouse events. instead of the visible ones the user thinks he is clicking on.
I worked around this in the meantime by setting the invisible tables to ZBottom. But there are also issues with invisible arrows from what I can see.
Re: Invisible tables and mouse events
Reply #1 - Mar 11th, 2008 at 10:56am
Set fcx.EventFlags(fNoClickEventsForLockedObjs) = True.
baron
Reply #2 - Mar 12th, 2008 at 2:44am
Thanks that worked. You may want to consider setting this to True by default for new Charts because most components work this way (i.e. disabled/invisible = no events) - but that's just a suggestion.
It seems when I post in the Bugs forum they turn out to be my lack of knowledge and when I post in Discussion, they turn out to be bugs  Wink
Reply #3 - Mar 12th, 2008 at 2:30pm
8) Actually the control uses the same event flag for both locked and invisible items. It sounds more logical to raise events for locked items, but not for invisible ones, so perhaps we should add a second flag to let you control the two cases independently from each other.
