Normal Topic Issue in Link (Read 1669 times)
dinesh
Issue in Link
Mar 13th, 2008 at 6:31am
Hi Stoyo!
In older version the following code appeared.
Arrow a = fc.CreateArrow(bp, bc);
a.TextStyle = EArrowTextStyle.atsRotate;
I have changed Arrow to DiagramLink like below
DiagramLink a = fc.Factory.CreateDiagramLink(bp, bc);
but i dont know how to change textStyle..
Help me Out
Note: I dont know how to insert Image Using tag in this forum. tell me Whether it will work
Re: Issue in Link
Reply #1 - Mar 13th, 2008 at 8:59am
Set link.TextStyle = LinkTextStyle.Rotate.
You cannot upload images here. You might upload them on your site or on flickr, and link to them using the tags.
dinesh
Re: Issue in Link
Reply #2 - Mar 13th, 2008 at 9:45am
In My Project I'm using Radial Tree.
My requirement is to delete all the link with blue color.
For that i'm using Following code. But it's not working
foreach(DiagramLink ao in fc.Links)
if (ao.Pen.Equals(Color.Blue))
ao.Visible = false;
is der any other way to do ..
Re: Issue in Link
Reply #3 - Mar 13th, 2008 at 10:51am
You should use Pen.Color.Equals(Color) to compare Color instances.
