Normal Topic How to bind a datatable to a piechart (Read 4977 times)
kiran
Mar 12th, 2008 at 5:40pm
I have only two columns, one column is type and second column is value. I need to draw pie and chart for the type vs value.
Re: How to bind a datatable to a piechart
Reply #1 - Mar 12th, 2008 at 8:37pm
Set the DataSource property to your table. Then assign the type's column name to the InnerLabelsField or OuterLabelsField property, and the value column name to DateField.
