Normal Topic After dragging node, it should be selected, how? (Read 1605 times)
consolejoker
Mar 16th, 2008 at 1:18pm
I have an unselected node. I then drag it (without selection it or clicking and releasing first) and then release it somewhere else.
It seems to remain unselected. How can you ensure that whenever a node is dragged, it should be selected once the drag operation is complete? Otherwise you have to click it again which is unintuitive.
Re: After dragging node, it should be selected, ho
Reply #1 - Mar 17th, 2008 at 8:12am
If you set DiagramView.ModificationStart = AutoHandles, the node should be automatically selected. Is that how you have implemented your drag operation?
consolejoker
Reply #2 - Mar 18th, 2008 at 3:08pm
Yeah that is how I have it but it's not remaining selected after I click and move it.
I guess I should clarify when i drag it, I am in one step clicking with mouse down and then moving and then releasing. It should remain selected but does not.
Reply #3 - Mar 18th, 2008 at 3:20pm
Are you sure you aren't deselecting the node in response to some event, e.g. NodeModified? Could you post here your DiagramView and Diagram initialization code?
