Normal Topic Avoid making new table object (Read 1030 times)
pritpal
Mar 17th, 2008 at 1:24pm
I need to disable  making new table object while we drag the mouse on flowchart.net  control.
Re: Avoid making new table object
Reply #1 - Mar 17th, 2008 at 1:48pm
If you want to let the user draw links between existing tables, set DiagramView.Behavior = DrawLinks. To prevent them from drawing any new objects, set Behavior = Modify.
