Normal Topic Change Shapenode Text (Read 1546 times)
mjweyland
Mar 19th, 2008 at 8:46pm
I am currently working with some custom shape nodes on a flowchart diagram. The top 70% is dedicated to an image and the bottom 30% is allocated for text for that shapenode.  I am however encountering a problem when the text to be displayed in a shapenode  exceeds the capacity designated on the shape node.  The text is truncated.
Is there  way to either A) change the height of the shape node to allow for all of the text to be displayed or B) Change the size of the font to allow for the text to be displayed while maintaining a minimum font size.
Thanks.
Re: Change Shapenode Text
Reply #1 - Mar 20th, 2008 at 9:08am
ShapeNode.ResizetoFitText(FitText.KeepWidth) should let you do A).
mjweyland
Reply #2 - Mar 20th, 2008 at 1:02pm
I'm already doing that and it is not reacting as expected.
