Normal Topic Problem with header selection (Read 1566 times)
Samun
Mar 24th, 2008 at 7:04pm
I am trying to select a header so that the user has the possibility to change the header title (after all, he might have made a mistake). However, I am unable to get the header object, I always get "nothing" as the header. Please find below my code. Hopefully you can tell me what I am doing wrong?
    Private Sub DiagramView1_MouseDoubleClick(ByVal sender As Object, ByVal e As System.Windows.Forms.MouseEventArgs) Handles DiagramView1.MouseDoubleClick
       Dim grid As Grid = Me.FlowChart1.LaneGrid
       Dim cellBounds1 As RectangleF = RectangleF.Empty
       Dim Mousepoint As PointF = New PointF(e.X, e.Y)
       Dim ThisHeader As Header = grid.GetHeaderFromPoint(Mousepoint, cellBounds1)
       If ThisHeader Is Nothing Then
           MsgBox("No Header selected!")
       Else
           MsgBox(ThisHeader.Title & " selected! - Row: " & grid.GetRowIndex(ThisHeader))
       End If
    End Sub
Re: Problem with header selection
Reply #1 - Mar 24th, 2008 at 8:08pm
Either handle the Diagram.DoubleClicked event which gives you the mouse position in document coordinates, or from the DiagramView handler call ClientToDoc to convert from pixels to document coordinates (millimeters by default).
Samun
Reply #2 - Mar 24th, 2008 at 10:30pm
Thank you, Stoyo, I did not realize that it was simply a matter of the units...
