Normal Topic Distribution2 (Read 1862 times)
Simone79
Distribution2
Mar 25th, 2008 at 11:44am
I use the flowchart.dll component in my software.
To create my software installer I use WiseInstallationExpress.
The software installation, and the software run without errors, but if I unistall my software, the windows drag&drop is disable.
I look this:
When I unistall the software the ole32.dll keys are deleted.
The keys are:
[HKEY_CLASSES_ROOT\CLSID\{00000320-0000-0000-C000-000000000046}]
[HKEY_CLASSES_ROOT\Interface\{0000000C-0000-0000-C000-000000000046}]
[HKEY_CLASSES_ROOT\Interface\{0000000e-0000-0000-C000-000000000046}]
[HKEY_CLASSES_ROOT\Interface\{0000000f-0000-0000-C000-000000000046}]
[HKEY_CLASSES_ROOT\Interface\{00000010-0000-0000-C000-000000000046}]
[HKEY_CLASSES_ROOT\Interface\{00000101-0000-0000-C000-000000000046}]
[HKEY_CLASSES_ROOT\Interface\{00000102-0000-0000-C000-000000000046}]
[HKEY_CLASSES_ROOT\Interface\{00000103-0000-0000-C000-000000000046}]
[HKEY_CLASSES_ROOT\Interface\{00000105-0000-0000-C000-000000000046}]
[HKEY_CLASSES_ROOT\Interface\{00000109-0000-0000-C000-000000000046}]
[HKEY_CLASSES_ROOT\Interface\{0000010C-0000-0000-C000-000000000046}]
[HKEY_CLASSES_ROOT\Interface\{0000010e-0000-0000-C000-000000000046}]
[HKEY_CLASSES_ROOT\Interface\{0000010F-0000-0000-C000-000000000046}]
Re: Distribution2
Reply #1 - Mar 25th, 2008 at 12:13pm
Do you have ole32.dll listed in your installer package? I suppose you should remove it since it is standard part of Windows, or at least use some option to let Wise ignore it when uninstalling.
