Normal Topic Position New Node After Auto Arrange (Read 1484 times)
mclellan
Mar 27th, 2008 at 3:41am
I am using the auto arrange feature to logically re-arrange my flowchart after I have dumped all of the nodes onto my page.
This is where I am stuck!
After everything is auto arranged, I would like to place a large chunk of formatted text centered at the bottom of the page. (This is a text description of what the flowchart is). Does anyone have an example I could follow?
Thanks!
Barry
Re: Position New Node After Auto Arrange
Reply #1 - Mar 27th, 2008 at 7:54am
You can use the Diagram.GetContentBounds method to find the rectangle that contains all diagram elements. Then display the description either by adding a text node just below that rectangle, or by handling the DrawBackground event and calling the DrawStyledText method from the handler.
mclellan
Reply #2 - Mar 27th, 2008 at 6:04pm
Excellent, thanks!!
