Normal Topic Left Justify Text when converting to VDX (Read 1553 times)
mclellan
Mar 28th, 2008 at 8:15pm
I have a node with several lines of text and I use the command:
node2.TextFormat.Alignment = StringAlignment.Near
To left justify this.
When I convert the output to .vdx the text shows up as centered.
Can someone tell me how to set my text as left justified? Maybe the left align attribute I am using is wrong?
Barry
Re: Left Justify Text when converting to VDX
Reply #1 - Mar 29th, 2008 at 9:38am
It looks this works only for styled text. We'll fix it for the next release. Until then, you could set EnableStyledText = true before exporting to Visio.
mclellan
Reply #2 - Mar 31st, 2008 at 3:27am
Worked great, thanks!
