Normal Topic Resize Node After Inserting Text (Read 4168 times)
mclellan
Mar 28th, 2008 at 8:26pm
I am using the following code to resize my node after I enter in about 30 lines of text - 134 chars each line (each line ends with a CRLF)
 Dim node2 As ShapeNode = VectorDiagram.Factory.CreateShapeNode(New PointF(VectorDiagram.Bounds.Width / 2, VectorDiagram.Bounds.Bottom + 2), New SizeF(45, 15), Shape.FromId("Rectangle"))
node2.TextFormat.Alignment = StringAlignment.Near
Dim r = New RectangleF(node2.Bounds.Left, node2.Bounds.Top, 20, 20)
node2.PolygonalTextLayout = True
node2.Bounds = r
node2.Text = "    Name:   "  & vvCrLf _
				    & vbCrLf & sVeryBigString
Font = New Font(FontFamily.GenericMonospace, 10)
node2.Font = Font
node2.ResizeToFitText(FitSize.KeepRatio)
When the node displays on my screen, the text 'almost' fits, but I still need to drag the node width wise a little wider to get each line to fit on one line without word wrapping.
Can someone tell me how to get each text line to fit on one line when I use the resize option?
Thanks!
Barry
Re: Resize Node After Inserting Text
Reply #1 - Mar 29th, 2008 at 9:47am
To fit the text without wrapping, enable the NoWrap flag in  node.TextFormat.FormatFlags.
mclellan
Reply #2 - Mar 31st, 2008 at 3:23am
When I add the line:
node2.TextFormat.FormatFlags = StringFormatFlags.NoWrap
Before using the ResizeToFit function, I end up with a rectangle with the height perfect, but the width of the rectangle is now half the size showing only 35 characters.
Reply #3 - Mar 31st, 2008 at 8:32am
Please save that node in a file and email it to support@mindfusion.eu.
mclellan
Reply #4 - Mar 31st, 2008 at 12:59pm
Thanks Stoyan,
Do you have an example I can use to just save a node to a filename?
Thanks!
Barry
Reply #5 - Mar 31st, 2008 at 1:23pm
Hi Barry,
Call Diagram.SaveToFile() after creating the node and setting its text.
Reply #6 - Apr 2nd, 2008 at 10:21am
It turns out ResizeToFitText doesn't honor the NoWrap flag when using the KeepRatio mode, so for now add this code:
n.TextFormat.FormatFlags = n.TextFormat.FormatFlags | StringFormatFlags.NoWrap;
n.ResizeToFitText(FitSize.KeepWidth);
n.TextFormat.FormatFlags = n.TextFormat.FormatFlags & ~StringFormatFlags.NoWrap;
n.ResizeToFitText(FitSize.KeepHeight);
mclellan
Reply #7 - Apr 4th, 2008 at 3:57am
Would you be able to translate that to a vb.net rookie such as myself?
Barry
Reply #8 - Apr 4th, 2008 at 2:20pm
Just replace the following symbols and remove the ";" from the line ends:
| -> or
& -> and
~ -> not
mclellan
Reply #9 - Apr 4th, 2008 at 3:05pm
Excellent, that worked perfectly!
Barry
