Normal Topic Is there a way to change cursor for only 1 col? (Read 1101 times)
consolejoker
Apr 1st, 2008 at 5:07pm
If I have a table node with 2 columns, I'd like the hand cursor only in the editable right hand column, leaving the standard mouse cursor for the left hand column.
Possible?
Re: Is there a way to change cursor for only 1 col
Reply #1 - Apr 1st, 2008 at 8:45pm
It's possible, but only through a custom Behavior object.
public class MyBehavior : LinkTablesBehavior
	public MyBehavior(DiagramView view) : base(view)
	public override CursorHint SetMouseCursor(PointF point, out bool startInteraction)
		CursorHint cursor = base.SetMouseCursor(point, out startInteraction);
		TableNode table = Diagram.GetNodeAt(point) as TableNode;
		if (table != null)
			int row = 0, col = 0;
			if (table.CellFromPoint(point, ref row, ref col))
				if (col == 0)
					DiagramView.Cursor = Cursors.Arrow;
					cursor = CursorHint.DontChange;
		return cursor;
Assign an instance of that class to DiagramView.CustomBehavior.
