Normal Topic Version 4.4 -> invalid .resx error (Read 2882 times)
quaint
Apr 2nd, 2008 at 11:46am
We just installed version 4.4 and now we can't compile anymore. We changed the references in all projects to the new version 4.4.0.26041 (.net 3.5).
The error:
Error1Invalid Resx file. The located assembly's manifest definition does not match the assembly reference. (Exception from HRESULT: 0x80131040) Line 166, position 5.C:\Projects\ZorgPlan .NET\Libraries\BaseControls\PlanningRoster\PlanRosterGrid.resx1665BaseControls
We tried deleting the .resx file, but it wasn't regenerated..
Please help us out, we can't get on with our work right now..
Re: Version 4.4 -> invalid .resx error
Reply #1 - Apr 2nd, 2008 at 12:18pm
Try to close your project, delete the 'obj' and 'bin' folders, then rebuild the entire project. If this does not help, I can suggest to manually edit the form's InitializeComponent method and remove all resources.GetObject calls regarding various Calendar properties that are saved and loaded from the form's resources. You may have to also edit the resx file of the form and remove the stored representation of these properties. Unfortunately this means that you have to reenter those properties once you are able to show the form in the design environment.
Hope this helps.
