Normal Topic Cannot copy attched shapes (Read 3597 times)
srlevitt
Apr 19th, 2008 at 1:54pm
I followed an example from a previous thread so I could have labels underneath my ShapeNodes. I created a descendant of ShapeNode which creates and attaches a label, e.g.
[code]
    class MyShape : ShapeNode
       Diagram diagram;
       public MyShape(Diagram d)
           : base(d)
           diagram = d;
           ShapeNode label = new ShapeNode(d);
           label.Text = "label text";
           label.Bounds = new RectangleF(PointF.Empty,
                                       d.MeasureString(label.Text, label.Font, int.MaxValue, label.TextFormat));
           label.Transparent = true;
           label.Locked = true;
           d.Nodes.Add(label);
           // attach the label to the icon
           RectangleF rc1 = this.Bounds;
           RectangleF rc2 = label.Bounds;
                                   rc1.Left + rc1.Width / 2 - rc2.Width / 2,
                                   rc1.Bottom + 1,
                                   rc2.Width, rc2.Height);
           label.AttachTo(this, AttachToNode.BottomCenter);
           this.SubordinateGroup.FollowMasterContainment = true;
    }[/code]
That all works OK. When I try to select and copy a "MyShape" using View.CopyToClipboard or CutToClipboard, I get an exception:
"Value cannot be null.\r\nParameter name: value"
   at System.Collections.CollectionBase.OnValidate(Object value)
   at System.Collections.CollectionBase.System.Collections.IList.set_Item(Int32 index, Object value)
   at MindFusion.Diagramming.DiagramItemCollection.set_Item(Int32 index, DiagramItem value)
   at MindFusion.Diagramming.Diagram.CopySelection(Diagram source, Boolean unconnectedLinks, Boolean copyGroups)
   at MindFusion.Diagramming.WinForms.DiagramView.CopyToClipboard(Boolean persist, Boolean groups)
   at MindFusion.Diagramming.WinForms.DiagramView.CopyToClipboard(Boolean persist)
   at MindFusion.Diagramming.WinForms.DiagramView.CutToClipboard(Boolean copy)
Is there a property I am not setting?
Re: Cannot copy attched shapes
Reply #1 - Apr 21st, 2008 at 8:35am
Have you added a Clone method or a copy-constructor to the MyShape class?
srlevitt
Reply #2 - Apr 21st, 2008 at 8:39am
No, do I need to?
Reply #3 - Apr 21st, 2008 at 8:59am
Yes, it is required if you need clipboard support.
srlevitt
Reply #4 - Apr 21st, 2008 at 8:01pm
I tried to implement a copy constructor like:
	  public MyShape(MyShape original)
		: base(original)
		diagram = original.diagram;
This stops the copyToClipboard crashing, but when I paste from the clipboard, it comes back as a ShapeNode. Why is this?
Reply #5 - Apr 21st, 2008 at 9:11pm
Call Diagram.RegisterItemClass(typeof(MyShape), "MyShapeID", 1); in your form's constructor. Otherwise, the serialization code will process your objects as ShapeNodes.
