Normal Topic Shapenode Label (Read 3019 times)
BidMaestro
to learn is to live
Shapenode Label
Apr 20th, 2008 at 11:50am
As a VB.net newbie I have been experimenting with flowchart.net (which is great) and I am looking for a simple method of
adding a label below a shapenode("Actor") with the format "SURNAME, Firstname, Middleinitial" as one line (no wrapping).
I used the technique in the predefined shapes example by attaching a hidden node for the label below the shapenode, however longer labels caused problems. I added code using measurestring from one of the forum examples to redefine the label bounds again this caused problems and I believe I am making the task harder than it should be.
Any suggestions would be appreciated
regards BidMaestro :(
Re: Shapenode Label
Reply #1 - Apr 21st, 2008 at 8:42am
The control leaves 1mm margins around the text, so add them to the result returned by MeasureString. Additionally, have you set the NoWrap bit in labelNode.TextFormat.FormatFlags?
BidMaestro
to learn is to live
Re: Shapenode Label
Reply #2 - Apr 21st, 2008 at 9:02am
Thank you for the prompt reply; I will test your response in the next few days. It maybe a suggestion for future releases that you could include a simplified label box for shapenodes rather than programming additional nodes and attaching them to label the shape. Or provide some different shapes with text areas outside the shape rather than embedded within the shape.
Once again, thank you for the great software.
Re: Shapenode Label
Reply #3 - Apr 21st, 2008 at 9:08am
Actually you can set the shapes' TextArea elements to be outside of the 0-100 range. Unfortunately, the ShapeDesigner does not support that yet, but you could do so from the Load event or constructor of your form:
Shapes.Actor.TextArea = new ElementTemplate[] { add LineTemplates with Y > 100 here }
BidMaestro
to learn is to live
Re: Shapenode Label
Reply #4 - Apr 21st, 2008 at 10:18am
Again, thank you for the response...this is where this newbie is going to get into trouble and will stick to simpler methods. I will try your first response and hopefully see some new developments in the shapenode label area in the future.
Thank you from the other side of the planet... Australia
