Normal Topic NetDiagram is not loading by using Telerik radAjax (Read 3286 times)
sripathi
Apr 22nd, 2008 at 1:18pm
I am using NetDiagram FlowChart (Demo Version) in my aspx web page. I am hiding and showing the boxes by clicking on the boxes. when I am doing this by using OnBoxClicked event, entire page loads/refreshes. To avoid this I am using radajaxmanager of Telerik controls to load the Flowchart. While doing this I am getting some unexpected javascript error.
Just wanted to know, whether Telerik radAjax is compatible with MindFusion NetDiagram FlowChart?
Can anyone please guide me?
Sripathi
Re: NetDiagram is not loading by using Telerik rad
Reply #1 - Apr 22nd, 2008 at 1:25pm
What is the error message? Anyway, try that with the 1.0.4 beta - it renders the HTML output in a very different way than V1.0.3 -
https://mindfusion.eu/_beta/netdiag_104beta.zip
Reply #2 - Apr 22nd, 2008 at 1:53pm
These dlls also require an updated version of ImageGen.aspx. You can get it by installing the full beta from https://mindfusion.eu/_beta/NetDiag104.zip, or otherwise edit the ImageGen.aspx.cs file and change the Page_Load method to
protected void Page_Load(object sender, System.EventArgs e)
     string typeParam = Request.Params["type"];
     string dataIdParam = Request.Params["dataId"];
     byte[] data = Session[dataIdParam] as byte[];
     Response.ContentType = typeParam;
     Response.Clear();
     Response.Cache.SetCacheability(HttpCacheability.NoCache);
     Response.OutputStream.Write(data, 0, data.Length);
     Response.Flush();
sripathi
Reply #3 - Apr 22nd, 2008 at 2:17pm
Thanks a lot Stoyo, I got the expected result by your response.
