Normal Topic DynamicResources do not work (Read 5095 times)
Todd
Apr 22nd, 2008 at 5:56pm
DynamicResources are not updated when using WPF Controls in a diagram. I've added a simple example that uses the SystemColors.WindowTextBrushKey as the foreground for two text blocks. One text block is added to a border the other to the diagram. If you change your Window Text color to say Red the bordered TextBlock will update, but the diagram does not. At first I thought that maybe I had to call RecreateCacheImage; however, that doesn't actually seem to exist.
<Window
x:Class="TestDiagram.Window1"
xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation"
xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml"
xmlns:d="clr-namespace:MindFusion.Diagramming.Wpf;assembly=MindFusion.Diagrammi
ng.Wpf">
<Grid>
<StackPanel>
<Border x:Name="MyBorder" />
<d:Diagram x:Name="diagram" />
</StackPanel>
</Grid>
</Window>
using System.Windows;
using System.Windows.Controls;
using System.Windows.Media;
using MindFusion.Diagramming.Wpf;
namespace TestDiagram
/// <summary>
/// Interaction logic for Window1.xaml
/// </summary>
public partial class Window1 : Window
public Window1()
InitializeComponent();
TextBlock text = new TextBlock();
text.Text = "Hello, Border!";
text.SetResourceReference(ContentControl.ForegroundProperty, SystemColors.WindowTextBrushKey);
MyBorder.Child = text;
diagram.Background = Brushes.White;
TextBlock text2 = new TextBlock();
text2.Text = "Hello, Diagram!";
text2.SetResourceReference(ContentControl.ForegroundProperty, SystemColors.WindowTextBrushKey);
diagram.Nodes.Add(text2);
DiagramNodeAdapter adapter = (DiagramNodeAdapter) Diagram.GetDiagramItem(text2);
adapter.Bounds = new Rect(100, 100, 100, 100);
Re: DynamicResources do not work
Reply #1 - Apr 23rd, 2008 at 1:12pm
It didn't work in our test too, but we don't know why. Our developer will try to find out more in the next few days.
Todd
Reply #2 - Apr 29th, 2008 at 12:40am
Stoyo,
I was wondering if any progress has been made on this issue? Is there a possible workaround until you are able to fix this issue?
-Todd
Reply #3 - Apr 29th, 2008 at 9:42am
We are working on it. Hopefully, the fix will be available this week.
