Normal Topic Customizing path to ImageGen.aspx (Read 2649 times)
jmcnair
Apr 24th, 2008 at 12:21am
Is there any way to customize the path to the ImageGen.aspx with the FlowChart control?  I would like to put the page somewhere other than the root of my website, maybe nested in a "tools" or "controls" directory, but I haven't figured out any way to change the path where the FlowChart control expects to find the page.
Is there any way to do this?
-Jason
Re: Customizing path to ImageGen.aspx
Reply #1 - Apr 24th, 2008 at 9:49am
This version adds an ImageGenLocation property:
https://mindfusion.eu/_temp/imagegen_location.zip
The property value is set as SRC for the IMG elements rendered by the control, and you could set it to say "tools/ImageGen.aspx".
jmcnair
Reply #2 - Apr 24th, 2008 at 10:06pm
Wow!  Was that a new build just for my question?  Thanks, you guys are awesome!
By the way, you should put that property in your permanent code base, if you hadn't planned to do so already.  Making that ImageGen location configurable will really help with keeping the website structure clean and organized.
Thanks again!
-Jason
Reply #3 - Apr 25th, 2008 at 10:55am
Yes, it is in the permanent code base now. We don't build any applications with our components, and don't know what people might need in real-world situations, so we mostly add features that our users request instead of inventing ones on our own 8)
« Last Edit: Apr 25th, 2008 at 2:41pm by Stoyo »
