Normal Topic CustomBehavior - How to make this happen? (Read 2918 times)
mikeaerni
May 1st, 2008 at 8:37pm
While the diagram is read-only (Behavior = DoNothing), I want to allow multi-select of ShapeNodes via rubber rectangle or ctrl-click. I'm trying create a CustomBehavior, but I'm not sure how to make it happen. Please help...
Re: CustomBehavior - How to make this happen?
Reply #1 - May 2nd, 2008 at 8:47am
Use the Modify behavior, and set EnabledHandles = None for all nodes. This will let you select nodes, but not move them.
mikeaerni
Reply #2 - May 2nd, 2008 at 8:50pm
I tried that, and it does get me closer -- it allows user to select multiple nodes via rubber rectangle. However, user cannot ctrl-click to select multiple nodes.
Reply #3 - May 4th, 2008 at 7:37am
That depends on the value of DiagramView.ModifierKeyActions.Control. Set it to Select and ctrl-click should work fine.
mikeaerni
Reply #4 - May 5th, 2008 at 9:22pm
I am a total dumb-a$$.   I was catching the MouseDown to manually select the nodes -- I had to do that because originally I set the Chart Behaviour to DoNothing.  Problem solved.  Thanks!!!
Reply #5 - May 6th, 2008 at 7:54am
