Normal Topic UndoManager - Layout action recording (Read 1513 times)
due
May 2nd, 2008 at 11:35am
The undo manager does not record the document resizing caused by automatic layouts.
The layout algorithm accordingly fits the diagram bounds to new layout size, but if you undo this action the original size will not be restored. Therefore, the user may see truncated diagrams (scrollbars are also unjustified).
However, undo calls will result in inconsistent diagram bounds (Diagram.Bounds). This invalid view state exists until diagram is resized (Diagram.ResizeToFitItems).
How can I handle this?  ???
Re: UndoManager - Layout action recording
Reply #1 - May 2nd, 2008 at 3:11pm
The Arrange methods do not change Diagram.Bounds; perhaps you are calling ResizeToFit after each Arrange? Anyway you can define your own commands to keep track of Bounds and other Diagram properties, e.g.
public class DiagramState : Command
	public DiagramState(Diagram diagram, string title) : base(title)
		this.diagram = diagram;
		oldBounds = diagram.Bounds;
	RectangleF oldBounds, newBounds;
	Diagram diagram;
	protected override void Execute(bool undoEnabled)
		newBounds = diagram.Bounds;
	protected override void Undo()
		diagram.Bounds = oldBounds;
	protected override void Redo()
		diagram.Bounds = newBounds;
and use it like this:
DiagramState diagramState = new DiagramState(diagram, "Bounds changed");
diagram.ResizeToFitItems(5);
diagram.ExecuteCommand(diagramState);
If you are always calling ResizeToFitItems after Arrange, you might prefer to do that as well in the ActionUndone and ActionRedone event handlers when they are raised for layout commands, instead of using a custom command.
