Normal Topic FlowChart.NET vs. NetDiagram vs. JDiagram (Read 2588 times)
tmtton
May 9th, 2008 at 1:24pm
What is the difference between FlowChart.NET and NetDiagram? Is NetDiagram is web enabled subset of FlowChart.NET? Is NetDiagram an ASP.NET equivalence of JDiagram? We want to develop a web tool that supports main features such as drag-n-drop diagram creation, XML file export/import, save as PDF and JPG. We have both .NET and Java developers in-house and want to determine which MindFusion products are suitable for our need. Thank you.
Re: FlowChart.NET vs. NetDiagram vs. JDiagram
Reply #1 - May 9th, 2008 at 2:32pm
Check this preview version of NetDiagram 2:
http://mindfusion.eu/Forum/YaBB.pl?board=netdg_disc;action=display;num=120937620...
NetDiagram implements client-side interaction using the Java applet implemented in JDiagram.jar, so it is a union of Flowchart.NET and JDiagram, rather than a subset.
With the version 2 release, the main difference between NetDiagram and FlowChart.NET will be in their DiagramView control implementations - one in MindFusion.Diagramming.WebForms namespace and the other in MindFusion.Diagramming.WinForms. All other classes - from the Diagramming, Import, Export and Layout - namespaces are now shared between the two components. We'll probably start beta tests for NetDiagram 2 on Monday.
