Normal Topic _propertyGrid text update from program (Read 2291 times)
kpdamico@aol.com
May 9th, 2008 at 4:40pm
I am attempting to update the text field in the _propertyGrid on the FlowCharter sample program.
I change the text in the node but cannot reach the text field in the properties table on the right hand side of the screen.
Does any one have a little snippet for doing this?
Re: _propertyGrid text update from program
Reply #1 - May 9th, 2008 at 7:15pm
In order to display just those three properties, the sample defines a NodeProps class and assigns its instance to PropertyGrid.SelectedObject, instead of the actual selected ShapeNode. So you must update the NodeProps.Text property too, or simply assign ShapeNodes to the PropertyGrid, instead of going through the intermediary object.
kpdamico@aol.com
Reply #2 - May 9th, 2008 at 9:15pm
OK - can you give me a VB snippet that will store
"XXX" in that text property window? Roll Eyes
Reply #3 - May 12th, 2008 at 9:26am
Dim node As ShapeNode = CType(_doc.ActiveItem, ShapeNode)
node.Text = "XXX"
_selected.Text = node.Text
_propertyGrid.Refresh()
"_selected" is the NodeProps instance that FlowCharter assigns to the PropertyGrid.SelectedObject property. So you just set its Text property along with the ShapeNode's Text. Note that _selected is Nothing when there isn't any selected diagram item.
kpdamico@aol.com
Reply #4 - May 12th, 2008 at 2:55pm
Stoyan,
Thanks, I'll give the snippet a spin.
Ken
