Normal Topic Change text for imported VISIO Shape (Read 1596 times)
JCRonSaratoga
Go Cubs Go!
May 15th, 2008 at 6:25pm
Hi:
How do I change the text for an imported VISIO shape?
I can change the shape tooltip using:
       For I2 = 0 To NumFlowChartShapes(0)
           diag.Items(I2).ToolTip = "Shape# " &  Str(I2)
       Next
Jim
Re: Change text for imported VISIO Shape
Reply #1 - May 16th, 2008 at 7:32am
Try this:
       For i2 = 0 To NumFlowChartShapes(0)
           Dim item As DiagramItem = diag.Items(i2)
           item.ToolTip = "Shape# " & Str(i2)
           If TypeOf item Is ShapeNode Then
               Dim shape As ShapeNode = CType(item, ShapeNode)
               shape.Text = "Shape# " & Str(i2)
           End If
       Next
JCRonSaratoga
Go Cubs Go!
Reply #2 - May 16th, 2008 at 1:36pm
Excellent!
Thank you, that works.
Have A Good Day,
Jim
