Normal Topic background image (Read 3312 times)
tmtton
background image
May 21st, 2008 at 4:09pm
I use flowChart.setImage(anImage) to add a JPEG image to the flowchart background.
1) flowChart.clearAll() clears both the diagram and the background. I have to make the setImage call again to restore the background. Can the background image stay in-place on a clear?
2) flowChart.saveTo(filename) does not save the background image. So no background seen after a flowChart.loadFrom(filename). How do I store the background image along with the diagram?
Re: background image
Reply #1 - May 22nd, 2008 at 7:45am
1) It can't. For the time being, you will have to save the result of getImage, call clearAll, call setImage again.
2) Try with FlowChart.getSerializationOptions().setBackgroundImage(true);
tmtton
Reply #2 - May 23rd, 2008 at 8:25pm
When saving the diagram, we like to have a store-background-image as an option. In most cases, we just need to save the diagram. But in a few cases, we want to store the background with the diagram. Does JDiagram 2 support that?
Reply #3 - May 24th, 2008 at 9:06am
We have removed the SerializationOptions feature from JDiagram 2, and the BackgroundImage is always saved. You can still achieve what you need by clearing the image temporarily:
public void saveDiagram(Diagram diagram, String fileName, boolean storeImage)
	throws FileNotFoundException, IOException
	if (storeImage)
		// saveTo always saves the image
		diagram.saveTo(fileName);
	else
		// set the image temporarily to null
		Image image = diagram.getBackgroundImage();
		diagram.setBackgroundImage(null);
		diagram.setBackgroundImage(image);
public void loadDiagram(Diagram diagram, String fileName, boolean loadImage)
	if (loadImage)
		// load the diagram with whatever image has been stored
		diagram.loadFrom(fileName);
	else
		// this will also load the image
		// restore the previous image
