Normal Topic Change Background color using WPF (Read 2269 times)
JCRonSaratoga
Go Cubs Go!
May 23rd, 2008 at 1:20pm
Hi: Using Windows Forms I was able to easily change the Background color of my diagram.  I have now moved to WPF.  Here is what I thought would work, but had not.   However, the "ShowScrollBars" statement does work.  This is in my .XAML document:
xmlns:mf="clr-namespace:MindFusion.Diagramming.WinForms;assembly=MindFusion.Diag
ramming.WinForms"
xmlns:mf2="clr-namespace:MindFusion.Diagramming;assembly=MindFusion.Diagramming"
    Title="MOM2" Height="980" Width="1200" Icon="file:///C:/MARS4/Archive/VBNET/MOM2/MOM2/mars-logo.ico">
    <Grid>
       <Grid Name="MainW">
           <wfi:WindowsFormsHost FontSize="18" Margin="0,25,0,0" >
               <mf:DiagramView x:Name="view"  BackColor="Khaki"  Font="Microsoft Sans Serif, 8pt" ShowScrollbars="False" />
Thanks, Jim
Re: Change Background color using WPF
Reply #1 - May 23rd, 2008 at 2:01pm
With that you are setting DiagramView.BackColor, but should set Diagram.BackBrush. I don't know if that can be done through XAML, but if it's possible, perhaps it will look like this -
<DiagramView ...>
  <DiagramView.Diagram BackBrush="..." />
</DiagramView>
You could add a Diagram to e Windows Forms form, set the BackBrush using the property grid, and copy the generated string value to the XAML file in place of the "..." above.
JCRonSaratoga
Go Cubs Go!
Reply #2 - May 23rd, 2008 at 2:21pm
Thanks. I couldn't figure out the XAML approach, so put it in the .vb code on load:
Me.view.Diagram.BackBrush = New MindFusion.Drawing.SolidBrush(System.Drawing.Color.Khaki)
This works!
Jim
