Normal Topic set minimum node size (Read 2156 times)
tmtton
May 23rd, 2008 at 8:34pm
ShapeNode's resizeToFitText(FitSize.KeepRatio) does resize the node to fit the text as expected. But in some cases, the node is resized too small (just enough to fit the wrapped-around text, for example). In JDiagram 2, is it possible to specify a node minimum size -- enlarge when necessary, but no smaller than a pre-defined size?
Re: set minimum node size
Reply #1 - May 24th, 2008 at 9:25am
You could apply the minimum size after calling resizeToFitText:
public void resizeToFitText(ShapeNode node, Dimension2D minSize)
	node.resizeToFitText(FitSize.KeepRatio);
	Rectangle2D bounds = node.getBounds();
	bounds.add(
		bounds.getX() + minSize.getWidth(),
		bounds.getY() + minSize.getHeight());
	if (!node.getBounds().contains(bounds))
		node.setBounds(bounds);
